Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will cover how to remove and replace the solid-state drive (SSD) in the Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if your SSD is faulty, which may prevent the computer from booting up. If you are having trouble with your computer, consult our troubleshooting page before replacing the SSD. Try powering on the device by holding the power button down for a few seconds while connected to a power source, and review our battery troubleshooting section to be sure that the SSD is at fault. Before beginning, be sure to power off your laptop and disconnect it from any power source.
Запчасти
Детали не указаны.
  1. Use a Phillips #0 screwdriver to loosen the five screws that secure the back cover to the laptop. The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
    • Use a Phillips #0 screwdriver to loosen the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Use a Jimmy to lift the cover directly up off of the locating pins. Though a  metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Once the case is lifted enough using the tool, grab the cover and take it the rest of the way off.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard. Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
    • Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
  5. Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
    • Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
  6. Carefully peel the thermal pad off of the back of the SSD. If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
    • Carefully peel the thermal pad off of the back of the SSD.
    • If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
Заключение
Michael Megna
Участник с: 23.01.2020
810 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S19-G4, White Winter 2020 Участник Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За всё время: 92
