Выберете то, что вам нужно
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Jimmy to lift the cover directly up off of the locating pins.
Remove the back cover.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
Use a PH0 screwdriver to remove the four 2mm screws holding the speakers in place.
