Введение
This guide will show you how to replace the daughterboard in your Lenovo ThinkPad X1 Carbon 7th Generation laptop. The daughterboard is home to the right-side USB port, so if this port goes bad, a daughterboard replacement will likely alleviate the issue.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
Remove the two 1.3 mm screws with a Phillips #0 screwdriver.
Disconnect the interconnect cable from the motherboard by flipping up the locking lever and pulling out the ribbon cable.
Lift the right side of the daughterboard up, then slide the daughterboard to the right to remove it from the computer.
