Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Back cover removal: шаг 1, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Back cover removal: шаг 1, изображение 2 из 2
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the back cover: шаг 3, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the back cover: шаг 3, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the back cover: шаг 3, изображение 3 из 3
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Unfasten the battery: шаг 4, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Unfasten the battery: шаг 4, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the battery: шаг 5, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the battery: шаг 5, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Remove the battery: шаг 5, изображение 3 из 3
    • Lift the battery straight out of its recess and remove it.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: шаг 6, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: шаг 6, изображение 2 из 2
    • Peel back the black adhesive tape covering the ribbon cable connecting the trackpad and fingerprint scanner to the motherboard.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 7, изображение 1 из 1
    • Unclip the connector ribbon from the fingerprint scanner by lifting upwards on the clip with an opening tool.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 8, изображение 1 из 1
    • Remove one 3mm screw from the fingerprint scanner mounting bracket with a Phillips #0 screwdriver.
    • Lift the fingerprint scanner mounting bracket upwards to remove it.
  9. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 9, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 9, изображение 2 из 2
    • Using an opening tool, lift the fingerprint scanner upwards.
  10. Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 10, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Fingerprint Scanner Replacement: шаг 10, изображение 2 из 2
    • Carefully lift the fingerprint scanner to remove from the chassis.
Заключение
2 участников успешно повторили данное руководство.
Jaxon Haws
Участник с: 01/23/20
574 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S19-G2, White Winter 2020 Участник Cal Poly, Team S19-G2, White Winter 2020
CPSU-WHITE-W20S19G2
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 41
За всё время: 1,154
