Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Back cover removal: шаг 1, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Back cover removal: шаг 1, изображение 2 из 2
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Remove the back cover: шаг 3, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Remove the back cover: шаг 3, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Remove the back cover: шаг 3, изображение 3 из 3
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Battery disconnect: шаг 4, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Battery disconnect: шаг 4, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Battery disconnect: шаг 4, изображение 3 из 3
    • Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Disconnect the battery: шаг 5, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Disconnect the battery: шаг 5, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Disconnect the battery: шаг 5, изображение 3 из 3
    • Use the flat end of a spudger to pry up on and disconnect the battery cable.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Lower Speakers: шаг 6, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement, Lower Speakers: шаг 6, изображение 2 из 2
    • Remove three 8mm Phillips #0 screws from both the left and right side speakers.
    • You are not required to remove the battery in order to remove these speakers.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement: шаг 7, изображение 1 из 1
    • Remove the insert connector from the motherboard by sliding it straight out from the port.
    • An opening tool can be used if a finger is too large.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement: шаг 8, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 7th Gen Lower Speakers Replacement: шаг 8, изображение 2 из 2
    • Lift speakers straight up and out of the device.
    • The two speakers are connected via a mutual wire, so they have to be removed and replaced together.
Заключение
Hayden Jeanor
Участник с: 01/23/20
511 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S19-G2, White Winter 2020 Участник Cal Poly, Team S19-G2, White Winter 2020
CPSU-WHITE-W20S19G2
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 49
За всё время: 1,559
