Введение
This guide will explain how to replace the motherboard in the Lenovo ThinkPad X1 Carbon 7th Gen.
With a damaged motherboard, the computer will likely not have any display, and remain a blank screen after being powered on. See our troubleshooting page for more details. The motherboard is required for components of the computer to communicate between each other, allowing the computer to run.
Before starting any replacement, ensure you power off and unplug your device.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
Remove the connectors with bar latches by lifting up on the small bar behind the port and pulling the circuit ribbon away from the port.
Remove the snap connectors by lifting straight up until the connection pops out.
Remove the latch connections by lifting the latch up, releasing the circuit ribbon.
Remove the seven 4 mm Phillips #0 screws that hold the motherboard in place
Remove the 3 mm Phillips #0 screw located near the fan.
Lift the motherboard with the fan still connected straight up and out of the device.
2 участников успешно повторили данное руководство.
Один комментарий
Do you have this motherboard? I bought this laptop a year ago and It does not power on. If you have any idea on it mail me at biplavraut@gmail.com or any link would be helpful. Thank you in advance.
