Введение
This guide will be most useful when the laptop has trouble opening smoothly due to its use over time. To access the hinges one must remove the motherboard and battery. Other guides are provided to complete this and warnings associated with those parts.
Выберете то, что вам нужно
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
Set the speaker modules out of the way.
Remove back panel and locate the connecting wires.
Disconnect the display connections on the motherboard.
Use a Phillips #00 screwdriver to remove the six screws (three on each hinge) securing the hinges to the main chassis.
Flip the display face up, then wedge a Jimmy between the display and the bezel, sliding and prying around the perimeter until the bezel releases.
Unscrew the first two exposed 1.2 mm screws with a Phillips #1 screwdriver, then peel back the adhesive to find and remove the third screw.
Lift the hinges up and off the display.
