Введение
This guide help you replace a failed or damaged keyboard. If you spill a drink or over a long period of time dirt can build up and prevent the keys from operating properly.
Выберете то, что вам нужно
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
Use a Phillips #00 screwdriver to remove the two 3 mm screws.
Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
Remove the silver plate on top of the charging port.
Disconnect all the ribbon wires from the motherboard.
All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
Disconnect the black attachment at the top right corner of the motherboard.
Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
While maintaining pressure, gently pull on the wire that is connected to it to remove it.
Use your fingernail or a nylon spudger to lift up the small locking flaps on the two ZIF connectors, then gently pull the ribbon cables directly out of their ports.
Use a Phillips #00 screwdriver to remove the four 6 mm screws securing the trackpad.
Use an opening tool to gently pry the touchpad buttons up and off, uncovering two screws.
Use a Phillips #00 screwdriver to loosen the two 4 mm captive screws under the touchpad buttons.
Use a Phillips #00 screwdriver to remove all eighty 6 mm screws on the back of the keyboard.
