Введение
In the event that the screen on your Lenovo ThinkPad X1 Yoga 2nd Generation gets cracked, has a distorted display, or fails to turn on entirely, use this guide to disconnect and replace the screen.
Replacing the screen requires taking out the majority of components from your laptop, so it’s advised that you keep every piece you take out as organized as possible to make for an efficient reassembly.
To stay safe and maintain the quality of your components, do not bend or hit the screen with too much force, as it is a fragile piece that will break under the wrong conditions.
Выберете то, что вам нужно
Follow the ribbon cable that runs from the left speaker to the motherboard.
Pull the black connector up and release the cable wire by hand.
Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
Lift up the small, metal tab using a spudger.
Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
Loosen the four 5 mm screws in the metal extension attached to the fan.
Remove the fan using your fingers.
Using a Phillips #0 screwdriver, remove all 16 of the 6 mm screws connecting the motherboard to the computer.
Using the nylon spudger, disconnect the grey and black wires.
Using the nylon spudger, gently disconnect the pink tab from the motherboard.
Lift the Black flap using a plastic spudger.
Pull out the ribbon cable with the black tab.
Using a Phillips #0 Screwdriver, remove the two screws securing the hinges to the back panel.
Using a metal spudger, pry the hinge open forcefully until it is clear of the back panel.
Еще один человек закончил это руководство.
