Введение
This guide shows how to remove and replace the battery on the Lenovo ThinkPad X1 Yoga (model number 20FQ005YUS). If the computer has a short battery life or is not charging at all, the battery should be replaced.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
Lift the plastic black strip cover that's laying over the battery connector.
Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
Gently pull the connector away from the battery to pull it out of the slot.
7 участников успешно повторили данное руководство.
One Comment
Hello, I was able to install the battery on my X1 carbon, but the laptop is not detecting my battery. How to remove whitelisting on X1 carbon yoga 1st gen?
