Введение
The keyboard is an essential component of the device so that a user can properly type a command into the device. If the keyboard isn’t properly recording your strokes, you may need to replace it.
Выберете то, что вам нужно
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
Lift the plastic black strip cover that's laying over the battery connector.
Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
Gently pull the connector away from the battery to pull it out of the slot.
Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
Gently peel back the black plastic covering around the fan.
Using an iFixit opening tool, flip up the small black cover of the fan plug.
Gently peel back the black plastic covering.
Remove the single Phillips #1 screw securing the wireless chip in place.
Use an iFixit opening tool to gently pop the gold caps off their connections.
Move these wires out of the way.
Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
Gently pull the cables out of the slots.
Using the Phillips #1 screwdriver, remove 23 (twenty three) 4.5mm screws.
9 участников успешно повторили данное руководство.
