Введение
The motherboard is the central hub of communication between all of the components in your device. If one or more components are failing in your device, it may be time to replace the motherboard. Use this guide to replace the motherboard in your laptop.
Выберете то, что вам нужно
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
Lift the plastic black strip cover that's laying over the battery connector.
Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
Gently pull the connector away from the battery to pull it out of the slot.
Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
Gently peel back the black plastic covering around the fan.
Using an iFixit opening tool, flip up the small black cover of the fan plug.
Gently peel back the black plastic covering.
Remove the single Phillips #1 screw securing the wireless chip in place.
Use an iFixit opening tool to gently pop the gold caps off their connections.
Move these wires out of the way.
Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
Gently pull the cables out of the slots.
Еще один человек закончил это руководство.
