Введение
Having a problem with Hard Disk in your Lenovo X240 ? Follow along while we show you how to get it replaced! All you need is your iFixit Toolkit.
  1. Flip the laptop upside down as shown in the photo.
    • Flip the laptop upside down as shown in the photo.
  2. Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop. Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Remove the back cover using the opening tools.
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Remove the Hard Disk Drive card by  screwing the 2 0.2mm Phillips screw
    • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
  5. Disconnect the SATA cable from the hard drive.
    • Disconnect the SATA cable from the hard drive.
  6. Take off the connector by carefully popping its holders out of place
    • Take off the connector by carefully popping its holders out of place
  7. Reconnect  the cable to the new Hard Disk Drive
    • Reconnect the cable to the new Hard Disk Drive
  8. place the connector in order to hold the cable
    • place the connector in order to hold the cable
  9. Place the new Hard Drive Disk
    • Place the new Hard Drive Disk
Заключение
8 участников успешно повторили данное руководство.
Mohammed Alsaadi
Участник с: 20.09.2017
510 Репутация
Автор 2 руководств
Команда
University of North Texas, Team S6-G2, Thomas Fall 2017 Участник University of North Texas, Team S6-G2, Thomas Fall 2017
UNT-THOMAS-F17S6G2
3 членов
Автор 4 руководств
Комментариев: 3
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - Ответить
Tip for the case screws, they are captive don’t worry about them
Baddo-M _ - Ответить
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
Ricky Las Vegas - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 36
За последние 30 дней: 152
За всё время: 10,308
