Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
Take off the connector by carefully popping its holders out of place
9 участников успешно повторили данное руководство.
5 Комментариев
Hello, i think you forgot to disconnect internal battery first before you replace something
That is true, that'd been a much safer way to do it.
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
If you have an SD card in the SD card reader make sure to remove it before trying to remove the case cover, otherwise it will not come off, and you risk damaging your motherboard if you force it.
