Введение
This will take approximately 45 minutes to complete from beginning to end.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
Remove the back cover.
Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
2 участников успешно повторили данное руководство.
