Введение
This guide will demonstrate how to remove and replace the battery on a Lenovo ThinkPad X390 Yoga.
Before beginning this guide, power off your laptop and unplug it from the charging cord.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
Once the back cover is no longer attached carefully remove it by lifting straight up.
Use the spudger to disconnect the battery from the motherboard at the connector socket.
