Введение
This guide will demonstrate how to remove and replace the fan and heat sink in the Lenovo ThinkPad X390 Yoga.
Before starting this guide, power off the laptop and unplug it from the charging cord.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
Once the back cover is no longer attached carefully remove it by lifting straight up.
Disconnect the fan connector from the moetherboard with a spudger or opening tool.
Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
