Введение
This guide will show you how to replace the touchpad of your Lenovo ThinkPad X390 Yoga.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
Once the back cover is no longer attached carefully remove it by lifting straight up.
Use the spudger to disconnect the battery from the motherboard at the connector socket.
Disconnect the touchpad ribbon connector from the motherboard using the opening tool.
