Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
  1. The first  step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. The next step is to simply move the switch from the locked position to the unlocked position.
    • The next step is to simply move the switch from the locked position to the unlocked position.
  4. Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
Заключение
2 участников успешно повторили данное руководство.
Ryan McCarthy
Участник с: 15.03.2018
748 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team S8-G2, Valliere Spring 2018 Участник UMass Dartmouth, Team S8-G2, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G2
2 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 375
