Выберете то, что вам нужно
Turn the device to the side as show in the image. Locate the following 1.5 mm Philip head screws as marked by the red circles in the image, and unscrew them.
Complete this exact procedure for the other side of the device.
Now that all the screws on the sides of the device are loosened, the out plastic coating of the screen has also become loose
Use a tool to pull apart this loosened plastic coating as shown in the image.
With the outer plastic coating now off, the inner screen is the only thing left to pull out. is the actual screen.
With the same tool used in the previous step, loosen the screen from all sides and simply pull it out as shown in the image.
It is at this point that you can replace the device with a new screen.
2 участников успешно повторили данное руководство.
