Введение
Follow these steps to replace your dysfunctional hard drive!
Выберете то, что вам нужно
Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
Once the back cover is exposed, remove the two screws holding the hard drive in place.
Remove the plastic encasing holding down the hard drive after screws are removed.
Carefully remove the plastic encasing surrounding the perimeter of the hard drive.
After the SATA connection is removed, gently pop off the hard drive from its socket.
5 участников успешно повторили данное руководство.
Один комментарий
