Введение
If the trackpad for your Lenovo Thinkpad Yoga 260 (Model Number: 20FD002HUS) is defective or broken, this guide will carefully walk you through the steps to replace it.
If your trackpad is not as responsive as it once was, the mouse not synced with your movements, or the trackpad not operating as normal you may consider replacing the trackpad.
Before using this guide ensure the laptop is powered off, disconnected from external power sources, and you have the listed tools available for use.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
Using a plastic opening tool, gently pry the bottom cover from the laptop.
Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
Fold back the plastic cover to access the battery connection.
Remove the battery connection using your two index fingers.
Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
Lift the battery free from its mounting and remove it.
Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
Flip the device right side up.
Open the computer.
Gently lift the trackpad out of the computer assembly.
3 участников успешно повторили данное руководство.
