Введение
For the Lenovo ThinkPad Yoga 370 (Model Number: 20JH002AUS), the Random Access Memory (RAM) is the memory module in the device that stores information. The RAM temporarily stores data and is the working memory of a computer. Oftentimes, the RAM can get overloaded and your device may experience various symptoms. These symptoms include but are not limited to: blue screen of death (BSoD), random freezing, slow performance, applications not loading, etc.
If you are looking to upgrade your RAM or replace faulty RAM sticks, this guide will show the process of replacing those components.
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, unscrew the eight circled 4mm screws until you hear a click.
Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
4 участников успешно повторили данное руководство.
