Выберете то, что вам нужно
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove two screws from the battery using a Phillips #1 screwdriver.
Disconnect the battery connector from the motherboard.
Remove the battery from the laptop.
Disconnect connectors. Use fingers to pinch and pull the connector out.
Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
Remove the fan from the motherboard.
Еще один человек закончил это руководство.
