Введение
A guide on how to replace the scree on a Lenovo ThinkPad E540 laptop.
Выберете то, что вам нужно
Remove the two stickers at the bottom corners for the screen to reveal the screws.
Remove the two 1mm Phillips #00 screws from underneath the stickers.
Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
Remove the plastic covering and six 1.3mm Phillips #00 screws from both sides of the display.
Remove the orange tape covering the display connector.
Disconnect the display's ribbon cable by lifting up the latch and flipping it over 180 degrees.
Еще один человек закончил это руководство.
