Введение
Are you experiencing difficulty connecting to the internet? Try replacing your WiFi card. This guide can help.
Выберете то, что вам нужно
Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
Disconnect the two antenna cables from the wifi card.
Remove the single 1mm Phillips #0 screw from the wifi card.
2 участников успешно повторили данное руководство.
2 Комментариев
Pictures show battery is still connected to laptop.
