Lenovo Thinkpad Edge E545 Fan Replacement
Выберете то, что вам нужно
  1. Lenovo Thinkpad Edge E545 Fan Replacement, Battery: шаг 1, изображение 1 из 1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Fan Replacement: шаг 2, изображение 1 из 1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Fan Replacement: шаг 3, изображение 1 из 1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Fan Replacement, Back Panel: шаг 4, изображение 1 из 1
    • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
    • It is recommend that you fully remove the screws and place them in a secure location.
    • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
  5. Lenovo Thinkpad Edge E545 Fan Replacement: шаг 5, изображение 1 из 2 Lenovo Thinkpad Edge E545 Fan Replacement: шаг 5, изображение 2 из 2
    • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
    • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
  6. Lenovo Thinkpad Edge E545 Fan Replacement: шаг 6, изображение 1 из 1
    • Remove the back panel.
    • The back of the laptop will be exposed once the panel is removed.
    • Many of these small components are easily damaged--do not touch anything unless instructed to.
  7. Lenovo Thinkpad Edge E545 Fan Replacement, Fan: шаг 7, изображение 1 из 1
    • Once the back panel is removed and the fan is accessible, remove the three 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
  8. Lenovo Thinkpad Edge E545 Fan Replacement: шаг 8, изображение 1 из 1
    • When the screws are removed, before the fan can be extracted, unplug the power connection to the fan by pulling it out of its socket.
    • With the screws removed and the power cable unplugged the fan can now be removed by lifting it out of its spot.
Заключение
John Metzger
Участник с: 12/03/18
190 Репутация
Автор 2 руководств
Команда
Purdue University Northwest, Team S1-G1, Hingst Fall 2018 Участник Purdue University Northwest, Team S1-G1, Hingst Fall 2018
PNW-HINGST-F18S1G1
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 702
