Введение
This guide will teach you how to remove the built in speakers when they begin to fail or are entirely unresponsive.
Guide Notes
- The keyboard must be removed before the plastic top case can be removed.
- When separating the keyboard assembly from the laptop, be mindful of the unseen ribbon cable that must be disconnected.
- The touchpad, like the keyboard, has a ribbon cable that must be disconnected while raising the cover away from the body of the laptop.
Выберете то, что вам нужно
Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
Ensure all 5 clips are loosened from the front of the keyboard before removing.
Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
Remove the keyboard from the device.
Remove the six 14.0mm screws with a Phillips #0 screwdriver.
Remove the three 3.0mm screws with a Phillips #0 screwdriver.
Snap off the top cover with a plastic opening tool, ensuring that the tabs don't snap back on.
4 участников успешно повторили данное руководство.
