Выберете то, что вам нужно
Flip the laptop over.
Place it on a flat, sturdy surface.
Remove the battery by moving the battery latch and slowly sliding the battery out.
Locate the drive enclosure.
Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
Remove the plastic rails from the old drive and place them on the new drive.
37 участников успешно повторили данное руководство.
Один комментарий
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
