Lenovo Thinkpad T430 Hard drive or solid state drive replacement
Выберете то, что вам нужно
  1. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the battery and locating the drive enclousure: шаг 1, изображение 1 из 1
    • Flip the laptop over.
    • Place it on a flat, sturdy surface.
    • Remove the battery by moving the battery latch and slowly sliding the battery out.
    • Locate the drive enclosure.
  2. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the screw in the drive enclousure: шаг 2, изображение 1 из 1
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
    • The screw is designed to remain within the plastic cover. (This is called a captive screw.) Don't worry about extracting it completely.
  3. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the drive enclosure: шаг 3, изображение 1 из 1
    • Carefully remove the drive enclosure cover.
    • Be careful not break the small latches on the sides of the cover.
    to avoid breaking those latches, the cover doesn’t come off in a straight line, it comes out sliding from the screw side rotating the cover around the other end (the end near the laptop corner area). If stuck, use the screwdriver to continually turn the screw counterclockwise while pulling. JD
    Jose D. - Ответить
  4. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Pull out the pull tab: шаг 4, изображение 1 из 1
    • Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
    If for some reason your hard drive doesnt have the ribbon then you better have a pair of tweezers and alot of patience, but with some rocking back and forth and a tight grip, you should be able to remove it
    Pretty Ryder - Ответить
  5. Lenovo Thinkpad T430 Hard drive or solid state drive replacement: шаг 5, изображение 1 из 1
    • Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  6. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the rails from the drive: шаг 6, изображение 1 из 1
    • Remove the plastic rails from the old drive and place them on the new drive.
Заключение
37 участников успешно повторили данное руководство.
Michael Khmelnitsky
Участник с: 08/14/13
982 Репутация
1 руководство автора
Один комментарий
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
Tom Midgley - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 44
За последние 30 дней: 216
За всё время: 65,637
