Введение
If you're needing to replace the battery on your Thinkpad, you can find instructions on how to do so in this repair guide. No tools will be needed to complete the following steps.
Выберете то, что вам нужно
Slide lock button 1 to the unlock position and gently slide away from your body.
Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
Еще один человек закончил это руководство.
