Введение
If you are encountering issues with your keyboard, there is a possibility that you might have to replace it. You can utilize this guide to receive step by step instruction to complete this task manually by yourself.
Выберете то, что вам нужно
Remove the battery by pulling on the two sliding buttons next to the battery.
Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
3 участников успешно повторили данное руководство.
Один комментарий
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
