Введение
Overtime, the trackpad is a component that is likely to fail. If the mouse isn’t properly tracking movements or if the mouse isn’t moving at all, your trackpad may need to be replaced. If you have noticed issues while using your trackpad or you simply want to replace it, this guide will lay out how to remove and replace it step by step.
Выберете то, что вам нужно
Remove the battery by pulling on the two sliding buttons next to the battery.
Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back cover and remove the back cover.
Using the Phillips #0 screwdriver, remove the three 5mm screws around the battery.
Unplug and remove the battery.
Remove the ten 5mm screws holding down the motherboard using the Phillips #0 screwdriver.
Use the Phillips #0 screwdriver to remove the single screw holding the hard drive.
Remove the hard drive from the device.
Using the Phillips #0 screwdriver, remove the two 5mm screws that connects the toughpad to the computer.
Remove the cable in the left hand of this picture that connects the motherboard to hard drive.
Using the Phillips #0 screwdriver, remove the the two 5mm screws in this image and then remove the glue flex cable being held.
5 участников успешно повторили данное руководство.
4 Комментариев
Hello,
I would like to ask you one thing - do you recall if the TouchPad can be adjusted (position wise) before srewing down? I have this problem where the right side on the TouchPad is too close to the palmrest (between spacebar and the TrackPoint buttons), and when I click the right physical button it collides with it, providing not so great using experience. So I was wondering it is posiible to losen the screws and move it back a little.
Is it possible? Thanks in advance for answear.
Do I have to reinstall drivers after this? I replaced the touchpad but now two fingers scrolling is not working. Any ideas?
Do I have to remove the keyboard to replace the touchpad for thinkpad t450?
It does not seem necessary when following the instructions above!
Will post here again to warn people. Be very careful when removing the flat flex glue cable that attaches to the motherboard. The clamp can easily be damaged by just manipulating the cable. Make sure to open the clamp first before removing or the clamp may break and will not be able to be replaced other than replacing the main board!
