Запчасти
No parts specified.
  1. Start by removing the button covers by prying them off.
    • Start by removing the button covers by prying them off.
  2. Next Remove the two screw found under the buttons.
    • Next Remove the two screw found under the buttons.
  3. Using a plastic opening tool carefully pry open the the outer perimeter of the tablet.
    • Using a plastic opening tool carefully pry open the the outer perimeter of the tablet.
  4. Next remove the ribbon cable  lift up the tab on the back end and slide it out. Only the back side of the cable has been removed—the other can remain connected.
    • Next remove the ribbon cable lift up the tab on the back end and slide it out.
    • Only the back side of the cable has been removed—the other can remain connected.
  5. Remove this screw and lift out the whole assembly. Remove this screw and lift out the whole assembly. Remove this screw and lift out the whole assembly.
    • Remove this screw and lift out the whole assembly.
Заключение
Juan Rojo
Участник с: 21.09.2018
174 Репутация
1 Guide authored
Команда
University of North Texas, Team S1-G2, Riccardelli Fall 2018 Member of University of North Texas, Team S1-G2, Riccardelli Fall 2018
UNT-RICCARDELLI-F18S1G2
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 67
