Lenovo Thinkpad Tablet 1838 Speaker Replacement
Выберете то, что вам нужно
  1. Lenovo Thinkpad Tablet 1838 Speaker Replacement, Speaker: шаг 1, изображение 1 из 1
    • Remove the middle button by putting a plastic spudger or your fingernail underneath the button and lifting up.
  2. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 2, изображение 1 из 1
    • There will be two screws under the button you have removed. Use your Phillips #00 Screwdriver to remove these screws.
  3. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 3, изображение 1 из 1
    • With a plastic spudger or your fingernail, find the seam where the front and back panel connect and pry open from the bottom. After making a small opening, go around the device counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 4, изображение 1 из 1
    • Before you separate the panels, there is a ribbon cable connecting the LCD to the motherboard. To avoid damage of the ribbon cable, lift the panel with the LCD from right to left like opening a book.
  5. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 5, изображение 1 из 2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 5, изображение 2 из 2
    • This is the speaker unit, and is being held by a screw. Use a Phillips #00 Screwdriver to remove the screw indicated by the red circle in the second image.
  6. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 6, изображение 1 из 2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 6, изображение 2 из 2
    • The speaker is still connected to the motherboard by a little connector. Using a plastic spudger or your fingernail, pry the connector to the direction marked by the two red arrows in the second image.
  7. Lenovo Thinkpad Tablet 1838 Speaker Replacement: шаг 7, изображение 1 из 1
    • After removing the connector, you can now remove the speaker. Use your spudger or fingernail to lift the speaker up. The speaker should come out easily.
Заключение
Arturo Barboza
Участник с: 10/26/17
209 Репутация
1 руководство автора
Команда
University of North Texas, Team S1-G2, Riccardelli Fall 2018 Участник University of North Texas, Team S1-G2, Riccardelli Fall 2018
UNT-RICCARDELLI-F18S1G2
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 150
