Введение
If your Lenovo Thinkpad X1 Carbon 4th Generation is experiencing black screens or going blank randomly, use this guide to replace the screen (also known as the display).
The screen uses a ribbon cable to send the information to the motherboard. A loose ribbon cable connection will cause the same issues like a broken screen.
Before using this guide, inspect the ribbon cable connection for a loose or non-existent connection, which has the possibility of making the screen dysfunctional. Be sure to fully reassemble the computer before testing the screen.
Before beginning, make sure to power off your computer completely and disconnect from any external power source.
Выберете то, что вам нужно
Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
Peel back the plastic protective cover above the main battery section to expose the coin-cell's red and black wires.
Gently unplug the coin-cell wires from the connector by pulling horizontally away from the connector.
Lift the coin cell out from the computer.
Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
Carefully lift the far end of the battery connector with an opening tool facing towards you.
Remove the connector by pushing it forward and lifting.
Disconnect the antenna wires on green the wireless LAN card to the left of the fan.
Lift up the hinge connector that is attached to the fan's ribbon cable.
Carefully disconnect the cable by pulling outwards from the ribbon connector.
Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
Using a Phillips #0 screwdriver, remove the two 5 mm screws securing the USB ports on the righthand side of the motherboard.
Using a Phillips #0 screwdriver, remove the five 5mm screws.
Using a Phillips #0 screwdriver, remove the four 2mm screws.
Remove the 7 ribbon cables connecting the motherboard to their respective components by flipping up the locking black tabs with a spudger and pulling the cables from their connectors.
Remove the red and blue wires attached to the motherboard.
Using the plastic opening tool, gently lift up on the motherboard.
Lift the motherboard out from the computer.
Using a Phillips #0 screwdriver, remove the four 5 mm silver screws from the display hinges.
Using a Phillips #0 screwdriver, remove the two 2 mm screws securing the wires in place.
Gently remove the wires from their tight fit pinch clamps.
Gently wiggle the display brackets back and forth until the display is off.
Insert the plastic opening tool into the side of the display in between the gaps, separating the bezel from the rest of the display.
Using a Phillips #0 screwdriver, remove the four 2 mm screws securing the display to the cover.
Lift up on the screen.
Disconnect the ribbon cable connecting the circuit board to the display.
2 участников успешно повторили данное руководство.
