Введение
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
Выберете то, что вам нужно
First you push the lock button on the back of the computer from lock to unlock.
Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
Using your fingers push keyboard forward so it is closer to the screen than it was before
Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Еще один человек закончил это руководство.
