Введение
Use this guide to replace the screen of your Lenovo Thinkpad X201 Tablet.
Выберете то, что вам нужно
First you push the lock button on the back of the computer from lock to unlock
Remove additional two screws near bezel screws plus the single logic board screw in the center
Gently pry the LCD cover with a flat head screwdriver, and pivot it over the signal cable near the LCD hinges. Pivot over all four corners
Continue to remove screens in front of the LCD cover, make sure all screws in the front are removed
Once all screws are removed, remove the LCD Display but gently peeling back line a sticker
2 участников успешно повторили данное руководство.
