Введение
This guide shows you how to remove and replace the battery in your Lenovo X220.
Выберете то, что вам нужно
Locate the two switches that lock the battery.
Then push the left switch outward into the "unlocked" position.
Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
To reassemble your device, follow these instructions in reverse order. Don't forget to switch the left switch back into the locked position.
3 участников успешно повторили данное руководство.
