Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will help you replace the back cover of your device. It's a relatively easy process, so sit tight and get your Phillips #0 screwdriver ready.
Выберете то, что вам нужно
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the blue Opening Tool to pry-open the back cover.
Slide it around the perimeter of the PC freeing the back cover.
Remove the back cover from the device.
