Введение
This guide will help you replace the RAM of your device.
  1. Flip the device so the back is facing you.
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Use the blue Opening Tool to pry-open the back cover.
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  4. Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick. Remove the first stick and and do the same thing to the second RAM stick.
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
Заключение
Ean Hobbs
Участник с: 18.01.2018
223 Репутация
Автор 2 руководств
Команда
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
За всё время: 59
