Введение
Are you having difficulties hearing conversations on your phone? Is the audio from your ear piece speaker breaking up? In this guide we will show you how to replace the ear piece speaker.
Выберете то, что вам нужно
Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
Push the Spudger along the gap between the phone and the backplate to separate them.
Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
Insert a fingernail or spudger into either side of the battery and lift upward.
Remove the battery from phone.
Gently remove the front-facing camera by gently lifting on the connector tab.
Remove the other connector by gently lifting with a spudger.
Gently lift the motherboard off the frame
Pull the camera out from behind the motherboard
Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
Remove the motherboard completely.
2 участников успешно повторили данное руководство.
