Выберете то, что вам нужно
Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
Lift the bottom cover off and set it aside.
Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
Slide the hard drive out of the casing.
With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
Unscrew the three M2x3mm Phillips head screws shown.
At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
Disconnect the two WiFi antenna cables.
Disconnect the sound connector.
Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
Detach the ribbon cables by opening the specified latches.
Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
Turn the laptop on its side and pry the bottom from the top.
Remove the ribbon cable by opening its respective latch.
Remove the specified cable on top of the motherboard.
Flip the laptop over, and remove the specified cables.
Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
Remove the motherboard with hands.
Unscrew (adequately loosen) the six heatsink screws in the order written on the heatsink. Use a Phillips #0 screwdriver.
These six screws are built into the heatsink and will not detach from it.
Unplug the fan cable from the motherboard.
Find an anti-microbial wipe and gently wipe the old thermal paste from the CPU and GPU
Now wipe the old thermal paste from the underside of the heatsink
6 участников успешно повторили данное руководство.
