Введение
If the LCD is broken or functioning poorly, it will probably need to be replaced.
Запчасти
Никакие детали не требуются.
  1. Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, at the specified locations.
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, at the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Remove the WiFi cables and the sound connector. (3 wires)
    • Open the laptop hinge, tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
    • Detach LCD assembly by unscrewing four M2.5x4mm Phillips Screws. (Two on each side).
    • Pull LCD assembly away from main frame.
    • Using a flat head screwdriver, wedge out two plastic tabs to reveal the screws.
      • One tab is in the bottom left corner and one is in the bottom right corner. Symmetrical locations.
    • Using a #0 phillips screwdriver, unscrew two silver M2.5x4mm screws.
      • These are located underneath the previously removed plastic tabs.
    • Unclip two latches, one in each bottom corner. They are located below the screws previously removed.
    • Place fingers to the inside of the bezel. Separate the bezel by pulling it away from the back cover. Pull until one side has been lifted.
    • Use the same technique to separate all remaining sides of the bezel.
    • Starting at one corner and making your way around, make sure the bezel is completely unattached from the back cover.
    • Completely remove bezel from LCD screen and back cover.
    • Unscrew the four M2.5x4mm Phillips screws at the designated locations. (One screw is located in each corner).
      • These are the designated screws.
    • Gently lift the LCD screen and flip it over.
    • On back of the LCD screen, locate the protective tape in the bottom right corner. Peel off the tape to reveal a latch with a connector cable.
    • Flip the latch so that the connector cable can be removed. Remove the connector cable by pulling downwards.
    • The old LCD is now completely disconnected and you are ready to install a new LCD screen.
Заключение
6 участников успешно повторили данное руководство.
Brandon
Участник с: 22.01.2015
455 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 21-21, Maness Winter 2015 Member of Cal Poly, Team 21-21, Maness Winter 2015
CPSU-MANESS-W15S21G21
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 5
За 30 дней: 44
За всё время: 4,288
