Введение
Sound is an integral part of a laptop user's experience, especially for videos, music, and gaming. The Lenovo Y50-70 Touch is equipped with two side speakers and a bass speaker on the underside of the laptop. When there are sound problems, but all the sound drivers are running properly, replace the speakers to regain your full user experience.
Выберете то, что вам нужно
Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
Lift up the fan slightly.
Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
Locate the three speakers within the laptop.
The bass speaker is located near the fan's original position.
The side speakers are located at the upper left and right corners of the laptop.
Using a Philips #1 screwdriver, remove the two 2.5 mm screws securing the bass speaker.
Using a Philips #1 screwdriver, Remove the 2.5 mm screw holding each side speaker to the laptop.
5 участников успешно повторили данное руководство.
