Введение
Batteries wear out over time and should be replaced if battery life becomes excessively short. Before removing this battery, be sure that the computer is turned off and unplugged.
Выберете то, что вам нужно
Remove all twelve 6 mm long screws on the back of the laptop with a Phillips #1 screwdriver.
23 участников успешно повторили данное руководство.
8 Комментариев
Is it possible to replace the original battery with one that has a larger capacity? With this I mean if the original battery has 3700 mAh, can it be replaced by a battery with e.g. 5000 mAh?
Perfect instructions. I took the battery out per Geek Squad instructions, put it back in but laptop is getting power as the charging light shows orange flashing like it is charging but won’t power up. Any ideas???
I read in the instructions when I first did the replacement that it might require disconnecting once or twice at a particular charge state to allow the laptop to understand the charge level of the battery. I can’t find those instructions. Any ideas??
I installed the battery properly, my laptop recognizes it, and it charges perfectly fine while plugged into a power source.
The problem comes when I unplug the laptop from the power source and force it to use battery power. It runs for another ~25 seconds and then it powers off instantly with a loud "pop" noise.
I'm not sure what the problem could be. Are you able to provide me with any troubleshooting steps?
My laptop works perfectly fine with the Lenovo battery it came with 5 years ago, though its life is a lot shorter than it used to be.
Have you found solutions to the problem ? Pls share having the same issue
I had the same issue.
At the end it was an incompatible replacement Battery. I bought another one from another shop - with the same specs as the incompatible one - but this time all was working fine.
I ordered and received the identical battery for my Y70 touch. Installed per instructions and does not acknowledge battery . Hover mouse over battery icon and reads “255% available plugged in” If I remove power adapter PC turns off.
Have u found any solution to the problems ? Pls share if you have. Facing the same issue
