Введение
In this guide, the reader will go through the necessary instructions needed to replace a non-functioning trackpad in the Lenovo Y50-70 Touch Laptop. This specific repair does not require any previous knowledge about computers and can be completed by a beginner using only a single Phillips #1 screwdriver and a small plastic prying tool.
When performing this repair, ensure you are in a static free environment so as not to provide an electrical shock to the computer and possibly further damage the device.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
Grab and pull off the back.
Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
Grab the battery cable and gently pull it free from the cable connector.
Remove the battery from the laptop.
Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
Grab the marked cable attached to the hard drive, and gently pull to unplug.
Remove the hard drive from the laptop.
Grab the top set of marked cables and pull up to remove them.
Grab the lower marked cable and pull it out from the plug.
Lift the black tab on top of the marked cable.
Grab the colored tab on the cable and pull to remove the cable.
Lift the black tab on top of the marked cables.
Grab the colored tab on the cables and pull to remove the cables.
Carefully remove the yellow tape on top of the cable.
Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
Grab and lift the heatsink off the motherboard.
Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
Grab and lift the motherboard up and out from the laptop.
Use a Phillips #1 screwdriver to unscrew and remove the two 6 mm screws at the top of the trackpad.
Push on the marked clips at the top of the trackpad.
Then, when undone from clips, lift the trackpad out from the laptop.
