Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will walk you through with replacing the fan of your device. You're going to need to sit down and unscrew a lot of screws to access the fan of your device.
  1. Flip the device so the back is facing you.
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Use the blue Opening Tool to pry-open the back cover.
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
Заключение
Trevor James
Участник с: 01.03.2018
85 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S2-G3, Munoz Winter 2018 Участник Eastern Washington University, Team S2-G3, Munoz Winter 2018
EWU-MUNOZ-W18S2G3
5 членов
Автор 4 руководств
Один комментарий
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 174
