Введение
This guide will show how to properly remove and replace the battery component. The safe disconnection of the battery is a key so that you do not shock yourself or any of the other components within the laptop.
Выберете то, что вам нужно
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Carefully remove the back panel by gently separating the panel from front to back.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
Еще один человек закончил это руководство.
