Выберете то, что вам нужно
With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
Using a Philips 00 Screwdriver, remove the four 4.762mm screws that hold the speakers in place (two for each speaker).
Locate and carefully detach the clips that connect each speaker to the computer.
Now that the speakers are completely free from the computer, you are able to remove each speaker and replace it.
2 участников успешно повторили данное руководство.
